no, its not. that means that the max fsb i could do with it is 160, and i dont think the chips on my board will go any higher than 150. now 150 is not bad, but i wanted something higher, like 180.Penguin4x4 said:980 is pretty damn good for PC800 RDRAM. The most 1066 can muster is @~1200. Do the math: 1200/1066 = X/800 X=900.
This argument is completemly illogicaly. Apple is severely anticompetitve in its approaches--notice how only Apple sells hardware for the Macintosh (the clone era, from 96 to 98, was killed by Apple). AMD is hardly on the "good side", as they're possibly the strongest backers of Microsoft's Palladium effort. As for the U.S.A., it's increasingly draconian and plutocratic.Penguin4x4 said:If they would just relase 64-bit RAMBUS......no no thats not going to help any. Think about it like this:
RAMBUS=Microsoft=IBM=Intel=U.S.S.R
DDR=Apple=Linux=AMD=VIA=U.S.A
DDR is "open-source" memory, so its free to use anyway you want it
RAMBUS is liscenced memory, so you must pay Rambus, Inc. to use thier technologies.
Daovonnaex said:Anyhow, I don't think one should exactly be celebrating a demise of RDRAM technology, as it is probably the most advanced DRAM architecture available. Latency in RDRAM decreases as speeds increase, unlike DDR SDRAM, where they increase.
The introduction of Intel's dual-channel DDR SDRAM chipset, code named Granite Bay, does not necessarily spell doom for RDRAM (by the way, that efficiency figure is largely the result of the fact that RDRAM is dual-channel at the moment, and furthermore, the i850 and i850E are not exactly steller memory controllers). [H]ard|OCP| tested a beta Granite Bay equipped board from Asus , and it was beaten by the Intel D850EMV2 equipped with PC1066 RDRAM. While the margins were slim, recall that the Intel D850EMV2 is the poorest performing i850E board by a fair deal.
32-bit RDRAM is nearly here. Asus is about to put the P4T533, designed for 32-bit RIMM4200 modules, into the retail channel. The majority of tests show this board completing demolishing the P4T533-C with two 16-bit PC1066 RIMMs or the Gigabyte i850E board (Gigabyte's naming scheme is confusing, sorry) similarly equipped. This solution will outperform the Granite Bay board, though the memory is more expensive (the Granite Bay chipset is more expensive than the i850E chipset, so costs may be offset).
As to RDRAM's future, soon 64-bit RIMM9600 modules will be available (PC1200, but 64-bits wide). Furthermore, by later 2003 ultra low-voltage RIMMs with ODR (octal data rate) may be available. That means that a 600MHz RIMM, instead of be PC1200, would be effectively PC 4800. A 64-bit PC4800 RIMM would provide 38.4 GB/second of theoretical bandwidth, and be low voltage to boot. Therefore, I wouldn't count RDRAM out just yet. It may have a rough year now, but it will definitely be back, and will likely replace current SDRAM derived technology (SDRAM, DDR SDRAM) and its future technology (DDR II, DDR III).
Actually, that's not really what vexes most. Rambus stole specifications from the JEDEC committee, including technology required for all DRAM chips. They then proceeded to launch one lawsuit after another against DRAM manufacturers, winnning some and losing others. They now face an FTC lawsuit over their unethical activities.Penguin4x4 said:Stiff Licsensing Fees
