Hi everyone,
I am running a Intel P4, 1.8a ghz, CPU on a Soyo Dragon P4S Ultra, with 1024MB RAM, ATI AIW 9800 video card, Creative Soundblaster Audigy 2 Platinum, and 4 hard drives (each 7200RPM, 8MB buffers).
I have a dual Win 2000/Win XP boot on the system
I actually just finished reinstalling Win XP after a corrupted file (froze during virus check and then when I rebooted, I couldn't get back in).
Anyway, my system was working fine yesterday morning. I turned it on to check a few things online before going to work.
When I came home from work and turned it on, all I got was a long beep from the motherboard and nothing else!
I checked the motherboard manual and it said to reset the CMOS (which I did), check the video card/ram connections (which I also did), but still no luck.
Any idea why this would happen? What do you think my next move should be? I have an extra video card around that I may test, but I don't think I have spare RAM. Those are 2 possible causes.
I should also note that my computer had been freezing up a lot during virus checks the past few weeks...I don't know if it was heat related. I have around 5 or 6 fans in the Thermaltake XaserV.
I also bought a pretty good power supply when I upgraded the case.
Thanks for your time
