- Oct 7, 2010
Hi, I have put together a new PC and it's all nice and cool, but I have a total of 6 (six) case fans (1x 22mm, 3x 18mm, 1x 14 mm, 1 x 12mm), plus 2 (two) 14mm fans attached to the CPU cooler.
Directly attached to the Power supply , these 8 fans make an unbearable noise. So something must be done and I was going to buy a fan controller because the situation just can't stay as it is now.
The question is: can I plug the CPU cooler to the fan controller (Rhoebus), so that I can control its fan speeds? Right now the CPU cooler is plugged into the motherboard, and if I want to change the speeds I need to use a program or to go into the bios, while I wopuld like to just have everything at hand (Case fans and CPU fans).
Imagine that the fan controller could theorically support my 4 pin CPU cooler AND my 3 pin case fans. Just tell me if this is doable. My fear is that the motherboard will "see nothing" plugged into the CPU fan socket, and not boot anymore or start warning me that my PC will melt soon if I don't do something about it.
CPU cooler Cooler Master V8 GTS (has 4 pin connector)
Motherboard ROG Rampage V Extreme
Fans have 3 pin male connector
