So this is my first attempt at overclocking anything, and I think it's going well. I brought my FX6300 up to 4.5ghz using only the multiplier and ran it for 2 hours in Prime Blend. I was able to do that at 1.3875 vcore, at 54C / 60C.
I'm now trying to tinker with the HTT (fka FSB?) and I've pulled some snips below. I'm starting to get concerned with temps; my CPU 0 and CPU both maxed at 63C. I checked the AMD website and it says max temp is 70.5C, but doesn't specify if that is core or socket. Regardless, CPU core should stay under 60, yes? Any recommendations on where to go from here?
