Can old applications and games be made to be displayed at higher resolutions?
c627627
c(n*199780) Senior Member
Good old Need For Speed II displays at 640x480, is there any way to make it display at higher resolutions or are old apps programmed to only be displayed at low resolutions?
_____________________
AMD Athlon XP 2500+ AXMH 2500 FQQ4C
IQYHA 0348 SPMW
2 x 512MB Centon PC3200 (Samsung chips) @ 9 4 4 3
[200] FSB x 12.5 = 2500 MHz @ 1.85 Vcore with memory frequency at 100% [200 FSB] @ 2.90 Vdimm and 1.6 Vdd
Epox 8RDA3+ v2.1, BIOS 07/29/2004
Thermalright SLK-900A with 80x38mm Delta EFB0812HHE fan
AIW 9600XT 128MB; Antec SX-835II case ; 380W Antec TruePower2 TPII-380
Five 80x25mm Case Fans
In general, no.
You just can't make sprites any bigger then they already are =P
I think alot of this stuff (resolution, even on older 3D engines) used to be hardcoded - some "newer old games" may have cracks to get higher resolutions, though.
