I tried that, twice, just now and the result was it wouldn't post.
I had to clear the bios and try again. My third attempt was to turn DOCP back on. when i did, i noticed it changed a lot of the settings on its own.
now, CPU-z is showing correctly.? i think??? yes??
Are you aware that CPU-z does not report the DDR frequency but the base frequency which will be half of DDR (Double Data Rate).
Do you have the latest bios installed on the motherboard?
You might also try bumping up the voltage a bit like from 1.35 to 1.4. The sub timings may be just a little aggressive for the IMC and sometimes a little extra voltage can overcome that.
