- Dec 13, 2012
- Wilrijk, Belgium
as the titel states i have about £60 to spend on one i heard good things about corsair
Well depending on your case size and if it will fit maybe something like this would do! AJ.
1, http://www.amazon.co.uk/Corsair-CWC...10?s=computers&ie=UTF8&qid=1356003751&sr=1-10
But the members and myself would need you to give us some more infomation to advise you better?
Welcome to OCF!!
Could you please copy and fill this information here?
Code:Motherboard: CPU and Cooler: RAM: Graphics Card: Storage Drives: Power Supply: Case: Operating System:
For LCLC loops, go H100/H100i or go air. A 140mm dual tower heatsink beats the H80 and is easier to mount.
Alas, your Z11 can't fit a H100, so I'd recommend you to go with Thermalright Silver Arrow SB-E.
EDIT: The signature only appears on post made after the signature creation.
how about the h60?
Not worth it, the Silver Arrow is GBP 59 with shipping.
and the Arctic Cooling Freezer Xtreme Rev.2 CPU Cooler is that one good too?
That is the worst thing you can buy with GBP 30, actually.
I had one, and it was worse than AMD's X4 stock cooler.
Cooler Master H212 for GBP 27
GBP 60 isn't too much for possibly the best air cooler around, if you were going to spend it on a subpar LCLC, IMHO.
I agree with Txus, you are better off with the Thermalright or the CM Evo over the h60. You said you wanted something reliable, aircoolers are much more reliable then water.Cooler Master H212 for GBP 27
