General_A6
- Dec 6, 2013
Hey guys,
today i thought of an interesting air flow setup in the computer keeping low temps.
right now i'm waiting for new parts to arrive from store so i can't try it out.
so if someone can try it for me and for the community it would be great.
needed parts: push-radiator-pull or push-push-radiator-pull and 2 x 140mm fans 120 can work as well but not as effective
The idea is to split the case into two parts with GPU (at lower pci-e slot) and the Upper drive base(rotating the upper drive base so the back side of it will be facing the front side of the case)
what do i mean is like on these drawings
do you think will it work?
can someone test it and post the results if it's better than a normal setup?
