- Mar 28, 2003
When I service my loop next month, I plan to swap out the EK CoolStream XE (360mm 60 mil) to an AlphaCool UT60 (also a 360mm 60 mil).
Should I expect much of a difference with cooling performance between the two?
I need the AlphaCool so thay I can add the drain port using the single end port on the radiator, while still retaining the inlet and outlet at the opposite end.
The Alphacool will be located on the floor of the case with fans (BeQuiet Light Wings) in a pull configuration, while the upper radiator is an XSPC RX360 (56mm), with the fans in a push configuration, all driven by an EK- XTOP D5 pump.
