Iron_Planter
- Jun 20, 2020
Greetings all,
I'm building a workstation PC and installing a custom water cooling loop. I need some help figuring out how to liquid cool my Firepro s9100 series server GPU's (see components list for models). I have a request out to EK and αcool for custom cooling solutions. I wondering if the community has any suggestions. I've done some comparing to the R9 290 series and the W9000 series cards. Unfortunately, the s9000 series is longer and the mounting holes don't line up. I'm looking in to a processor only waterblock and sticking air cooling heatsinks on the HBM and VRM modules with something like the Kraken G12 shroud and a high CFM fan as a secondary solution. Before I pull the trigger on that I want to make sure I've exhausted my other options.
Components:
Cooling:
Positive pressure fan configuration:
Custom water loop thus far:
Case:
I'm hoping to get this build done by the end of July 2020.
Any help is greatly appreciated. I'll post build progress pictures as it progresses.
Components:
- Motherboard: ASRock ROMED8-2T
- CPU: AMD EYPC 7402P
- RAM: 2x eventually 8x NEMIX RAM 32GB Replacement for Samsung M393A4K40BB2-CTD DDR4-2666 ECC RDIMM
- 2x AMD Radeon Firepro s9150
- 2x AMD Radeon Firepro s9170
- PSU: EVGA SuperNOVA 1300 G2 120-G2-1300-XR 80+ GOLD 1300W
Cooling:
- 3x Apevia 412L-RGB fans
- 2x Thermaltake TT-1425 fans
- EKWB EK-CoolStream Classic SE 360 Slim Radiator
- Thermaltake A1 TT RGB DDR3/DDR4 Water Block CL-W239-CA00SW-A
- Alphacool 12950 Eisblock XPX Aurora PRO
- Alphacool 13324 Eisball Digital RGB - Plexi (incl. Eispumpe VPP755 V.3) Water Cooling Reservoirs
- Mayhems Ultra Clear Tubing (3/8 - 1/2) 10/13mm (soft) Tubing
- Compression Fittings
- Distilled Water
- GPU cooler: ?
Case:
- Thermaltake Level 20 HT CA-1P6-00F1WN-00
