- Jun 15, 2011
Build log: Dual SR2 360 rads in Lian Li PC-O11 Dynamic (finished)
PHOTOS OF FINISHED BUILD ON PAGE 2.
It's time to upgrade the old i7-2600k workhorse I've had since 2011, and it was fun posting my progress on that build here on this forum. This will be my second custom water cooled build ever, and I'll try my hands on hard tubing for the first time. Priorities for this computer will be as little noise as possible with effective (oversized?) cooling, but still powerful components with headroom for overclocking. The plan is to use radiators designed for low rpm fans to reduce noise as much as possible. I'll try to cram in some RGB heaven (hell) too. Some components are in shipment, so I'll update the post from time to time during the build. First thing will be to check that all components works with stock air cooling, then I'll dismantle everything and start the water job. The size of the radiators will make this a tight fit, but I hope I'll be able to connect everything.
Components:
Case: Lian Li PC-O11 Dynamic - white
PSU: BeQuiet Dark Power Pro 11 850W
Motherboard: Gigabyte X570 Aorus Elite (non-WiFi)
CPU: AMD Ryzen 9 3900X
RAM: G.Skill Trident Z DDR4 RGB 2x16GB 3200Mhz CL14 (F4-3200C14D-32GTZR)
M.2: Samsung 970 EVO Plus 2TB
GPU: Gigabyte 2080 Ti Gaming OC
Cables: ATX, CPU and 2x 8-pin GPU extension cables from Mainframe customs (Black, carbon fibre, fusion gold/black)
Etc: Low profile USB 3.0 + 2x 9-pin USB 2.0 extension cables
Cooling:
Radiator top: Hardware Labs 360 SR2 (fans configured as push - exhaust)
Radiator bottom: Hardware Labs 360 SR2 (fans configured as pull - intake)
Pump: EK D5 PWM sleeved
Reservoir: Singularity computer Protium 100mm cylindrical - clear acrylic top
Reservoir mount: Singularity computer Core - black
Pump top: Singularity computer clear acrylic
Pump cover: Singularity computer black/silver
Fans: 9x Corsair ML120 RGB (3x top, 3x bottom, 3x side)
CPU water block: Heatkiller IV PRO (AMD, AM4 ready) Acetal
GPU water block: Heatkiller IV for RTX 2080 Ti - Acetal/Nickel w/ backplate
Thermal grease: T-Grizzly Kryonaut
Tubing: EK 12mm PETG
Fittings: EK HTC Classic Black Nickel 12mm
Coolant: EK Cryofuel clear
Fan/RGB/pump control:
Fan controller: Aquacomputer Aquaero 6LT
Fan controller cooling: Aquacomputer passive heatsink - black
Water temperature probe: Aquacomputer G1/4 plug for Aquaero
Air temperature probe: Aquacomputer probes included with Aquaero
Flow meter: Koolance INS-FM19
Fan RGB controller: 2x Corsair Lightning Node Pro + 2x Corsair RGB hub
Fan splitter - 3x EK 3to1 PWM splitters
Components:
Cooling:
