Funkman111
- Oct 29, 2016
Hi, I use a pc that is four years old for a lot of gaming and web browsing. Currently I am living with my parents and using their wifi internet. Today I was playing world of tanks when it started stuttering and lagging. I went out and turned the modem off and on again (it has no reset button) I have done this hundreds of times before and it usually fixes the problem.
Well when I came back there was no internet at all on my computer. I restarted 3 further times with the same result. Then I saw my mother using her ipad no problems, so I tried my tablet and found the internet works fine on my tablet.
I experimented with a few things on my computer, and I found that steam loads and updates itself fine, but when it tries to display the steam homepage or steam news pop ups, it displays an error and cant load them. When I try to loggin to World of Tanks, it wont log in and gives me an error.
Clearly there is still some network functionality as Steam was able to update itself, but there is absolutely no internet connectivity.
So does anyone know what the problem is - software or hardware? I suspect I may need to buy a new wifi card, would that likely fix the problem?
Thanks for your help.
