- May 15, 2006
thanks... will give it a go (when i have time)thideras said:
eaglescouter said:run a hijackthis log and get it analyzed.
Inside msconfig:
Disable non-microsoft/non-critical services.
Disable all unknown items in the startup list.
thx man... guess i'll try that tonight.Jon said:Startup regedit, go to Edit > Find and do a search for tkqlhce. May also want to try a search for NameServer to see if a DNS hijack has embedded itself in there somewhere. You might even want to try to do a nslookup on configure.us.dell.com and see what is returned.
Don't delete anything if found...report any findings first. Removing entries can cause you to loose any ability to browse.
I could not find tkqlhce anywhere...Jon said:No, do an actual search for "nameserver". I can't remember the exact key, but a DNS redirect is possible using the registry even if TCP/IP properties shows something else.
Server: UnKnown
Address: 192.168.1.1
Non-authoritative answer:
Address: 143.166.83.15
Aliases: configure.us.dell.com
Server: dhcp25.srv.prnynj.cv.net
Address: 167.206.245.16
Address: 143.166.224.188
ohhhhhhhhhhhh i get it... i get it i get it.Jon said:You shouldn't have to alter anything, but you're the one with the issue :\
Those links are supposed to register your click with wherever the redirector is at (tkqlhce.com, linksynergy.com) then shoot you to the real site. You're just not getting the full redirect...you're getting stuck at the redirector. There has to be some sort of setting that is not allowing the redirect to take place...or a shared .dll somewhere that all your browsers are using is borked. I can't really think of anything else. Considering it's not only IE, I guess security settings aren't the cause. All that's left are firewalls, antivirus, web proxy, etc. that may be installed.
g0dM@n said:i wonder if a slickdeals mod/admin would have heard about this b4... should i waste my time trying one of them?
you're good, Jon... you're good!!Jon said:There's nothing they can do for you...their links are working. I've tried them on 3 different systems at home and here at work without a single problem. There's just something that's intercepting that redirect and isn't allowing it to pass through, which is why I suggested the browser security (but that wouldn't account for it happening on other browsers in the same manner - they all handle it a little differently). There has to be something running externally that is blocking specific redirects.
