dump that cpu on ebay and get a D0, 1.4 is way to much for 4.0ghz HT off most chips can pass linx with flying colors below 1.4v. Dump it on ebay before the value drops further. You don't have much headroom left considering the voltages you are running.
Try upping the QPI to 1.42v it should help stablize your ram settings.
try lowering the mem multi, may be a not good mem controller on the chip
I dunno if it is my mobo or the chip but i gave up and went auto on all voltages have turbo enabled with ht. This is alot more fical than my e6600 system when it comes to adjusting volts it seems.But i have it running stable @ 4.0ghz so far. *edit* nm just crashed i'll just chalk it up to being a bad chip to oc with i guess.
