Hey guys,
I have a Gigabyte Z390 Aorus Master w/ an i9 9900k running very stable at 5.1GHz (1.3v).
I just plugged in a newly acquired GC-Titan Ridge PCI-E card and the system now won't boot. It tries a bunch of times then eventually resets the BIOS settings to factory, and boots this way. The system only seems to want to boot with "optimized defaults" loaded.
I'm confused because the overclock is not actually what seems to cause the issue. I have loaded my OC settings then changed the multiplier manually to 36 (default), and that didn't boot up either.
What could be the issue? Is there another OCing setting that might be affecting PCI-E cards? I have 2 GPUs, 1 wifi/bt card and 2 NVMe and they're all fine.
Thanks in advance!
Thanks in advance!
