As the title says I can't figure out how to flash a modded 9800GT BIOS. What happens is, it seems to work fine when I save the bios file with GPU-Z then modify the clocks in NiBiTor, but when I try flashing it with nvFlash version 5.370 or 5.287 it gives me this message:
The command I entered was:
With "G92-OC" being the BIOS file. Also i'm not sure what the first GPU it shows is, but that isn't really important.
Please ask if you need more information, and thanks in advance!
Code:
NVIDIA Firmware Update Utility (Version 5.287.0)
Modified Version By Joe Dirt
Checking for matches between display adapter(s) and image(s)...
Adapter: BR04 (05B1h) (10DE,05B1,10DE,C55E) H:--:NRM S:00,B:02,D:00,F:00
Adapter: GeForce 9800 GT (10DE,0614,3842,C982) H:03:SP0 S:00,B:04,D:00,F:00
No matches found.
Code:
nvflash G92-OC.rom
