Hello all,
New guy here to this forum, Need some help as I'm frustrated and cant seem to get answers back from suppliers.
I decided to build another computer as my previous one wont hold up to my applications like photoshop, dreamweaver, battlefield ect.
Here is my build:
Enermax ELC-LMR240-BS Liqmax II 240 Liquid CPU Cooler 25mm Fan
AMD FX-9590 Vishera 8-Core 4.7 GHz Socket AM3+ 220W FD9590FHHKWOF- Black Edition
GIGABYTE GA-990FXA-UD5 R5
G.SKILL TridentX Series 32GB (4 x 8GB) 240-Pin DDR3 SDRAM DDR3 2400 (PC3 19200) Model F3-2400C10Q-32GTX
SAPPHIRE Tri-X Radeon R9 390X DirectX 12 100381OC-2L 8GB 512-Bit GDDR5
3 SAMSUNG 850 EVO 2.5" 500GB SATA III 3-D Vertical Internal Solid State Drive
CORSAIR RM1000i 1000W ATX12V PS
Windows 10 Pro
So it wont run the ram at all... It wont even stay stable at 1333mhz. Right now I dropped cpu voltage from 4.7 to 3.7 and its running at 1333mhz ... for the last 10 mins. lol... (as I'm writing this for the third time.) Ive tried running 2400 gskill and 1866 gskill... at every setting I can think of ( No real experience)
Any ideas on the settings in this bios that I could be missing? I went on gigabytes website to see latest driver and It says on their U.S site that the latest Bios version is F2. Well... in my bios its showing I have F3.
Could this be a bios beta version and crap? Or is there something on AUTO that I need to turn off? I was thinking about saving the current bios to my flash drive and then rolling back on the F2 just to see. Ive put in a support ticket days ago to gigabyte with no answer. (very frustrating)
Has anyone else run into this?
Option 2: Does anyone know if I should invest in a different motherboard as I thought this work work perfect... I'm no pc daily builder but I have always put my builds together. Here and there little glitches but nothing like I'm having with this.
Any help would be much appreciated.
Thank you, Happ
Here is my build:
Windows 10 Pro
Thank you, Happ
