- Oct 10, 2003
- sweden (I am a viking)
About 18 months ago i ripped out my ABIT KT7-r and changed a whole bounch of faulty capacitors, although i didn't bother to change the healty ones. Now in the past few weeks my system started acting wierd i even had to downclock from 2,2 to 2.0 ghz to make it stable. A quick look a the motherboard made me realize the problem BAD CAPACITORS AGAIN!
I felt pretty stupid not having changed them all the first time...
Anyway I didnt feel like pulling everything out the case watercooling, cables etc so i decided to this the lazy way
I simply tilted the capacitors back and forth until their pins broke and then i solderd short cables (about 3cm long) to the solder pad where the capacitor had been sitting and solderd the new capacitor to the cable's. Doing it this way enabled me to do this "repair" without pulling evrything out of the case. To prevent the new capacitors from "hanging loose" in my case i used some melt glue to attach them to board. It sure may look abit ghetto and it sure is abit ghetto but IT WORKS!
Pictures here:
http://www.canit.se/~unlogic/kondingar/page_01.htm
Ps. As you can see i took the chance to replace the capacitors with bigger one's i figured it couldn't hurt
Pictures here:
