ryguy762008
- Jul 6, 2015
Hey fellow water coolers:
I am doing my first hard tube loop. I got bitspower 16mm OD PETG and some 16mm bitspower enhance multi link for OD 16mm. (links to parts below)
https://pcpartpicker.com/product/pc...-for-16mm-od-rigid-tubing-deluxe-white-4-pack
https://shop.bitspower.com/index.php?route=product/product&path=130&product_id=2901
The problem I am having is when I insert the PETG into the fitting, it only goes in like 1mm. It definitely doesn't go the whole way back to hit the interior wall of the fitting at 5mm.
I did one run between fittings of this type and tightened everything up. With some gentle pulling it feels secure, but I'm a little nervous. I can't imagine that's enough overlap, even with the o rings, but that could be just because I'm used to soft tube compression fittings.
Is the PETG suppposed to go the whole way in? If so, what am I doing wrong?
BTW, I double checked the sizes on the labels on both the fittings and PETG.
Thanks!!
Thanks!!
