- Nov 12, 2011
In my DRAM configuration in my bios the cas latency is listed as 11, however on newegg my ram's cas latency is 9. Should I change this in the DRAM config?
If you look at the 1st SS from post #8 the Ram was running at 819.2 which is roughly 1640mhz. Did you have the BLCK adjusted up?No I had no idea they were overclocked. I'll try changing the timings. Should the Mhz be up at 1600 and not 800? The ram is rated 1600 is why I ask.
