GB IT fool
- Feb 3, 2013
- Portland, OR
I have been stareing at the fans on New Egg for a while and I just unsure of what to buy I have read a lot of reviews, but those seem very hit and miss with varying opinions.
Here is my purchases so far.
MB:ASUS P8Z77-V PRO LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Processor: Intel Core i5-3570 Ivy Bridge 3.4GHz (3.8GHz Turbo Boost) LGA 1155 77W Quad-Core
Memory: CORSAIR Vengeance 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
Case: Thermaltake Level 10 Series Level 10 GTS Black SECC ATX Mid Tower Computer Case
First question: Should I replace the existing case and CPU fans? Currently just using the stock fan that came with the i5-3570
Here is what the case takes for fan:
HDD Air Cooling System
1. Front (intake) : 200 x 200 x 20 mm Blue LED fan (600rpm, 13dBA) - Included
CPU Air Cooling System
2. Top (exhaust) : 200 x 200 x 30 mm fan x 1 or 120 x 120 x 25 mm fan x 2 (Optional) -
3. Rear (exhaust) : 120 x 120 x 25 mm Turbo Fan (1000rpm,16dBA) - Included
4. Side (intake) : (optional & only for None window version)
200 x 200 x 30 mm fan or 140 x 140 x 25 mm fan x 1
CPU cooler height limitation: 175mm
I would like to get some blue/red led fans. What should i get that is both reliable, decently quiet and provides sufficient cooling. Oh and again must look cool. Have no interest in water so air only recommendations please.
Budget: under $100 i think is reasonable if recommended to replace and add all new.
Thanks
Thanks
