- Oct 13, 2004
So I recently bought the Corsair 175R, but I’m really not that happy with it. My H100i doesn’t really fit because the fans hit my RAM heatsinks, and airflow is not great.
I need something that can provide my Vega 64 reference design blower card cool air because right now it’s running too hot.
-it’s hitting 85C at 1000mv and 1550MHz..so it’s due to poor air flow not the voltage. It drops 15C if I remove case cover so I know it’s airflow.
Can someone recommend a good airflow case? Here’s my needs list:
-must support 240mm AIO up top with fans without hitting RAM slots, so needs some space.
-Good front airflow for 3x120mm or 2x140mm
-Glass side panel
-not an obnoxious design. Something clean and simple.
-$150 budget.
-Mid ATX is possible.
-Not a “square case”, traditional shape to fit on my desk.
-Glass side panel
-$150 budget.
