- Feb 29, 2012
Having seen things like this http://cablesaurus.com/index.php?route=product/product&product_id=12 as well as the riser cards (which are typically used to put an x16 low profile card, into an x1/x4 slot since many x1 video cards are overpriced) but not seeing any cases seemingly designed for this (either for where to put the other end of the card-on-cable, or if say I used a full height video card on the x1/x4 riser, not necessarily high performance or anything just because I have it around to say put graphics onto a mobo i'm using as a server, because i want the x16 slot/s for hard drive RAID cards and it lacks on board graphics) i'm curious how do people mount them?
Or if people have any clever ideas for inexpensive (functional more than cool) casemod stuff to merge two cases together so that the video card can be securely mounted, obviously away from the board since the cables allow up to 19cm.
I mean off the top of my head I was considering getting two cheap ATX cases and just making them permanently side by side, welded or bolted together or something. Both to get the 2nd row of hard drive mounting options, and to use the 2nd case's slot backplane to screw a couple cards used in the new higher 2nd position. Though that doesn't stabilize the bottom of the card which is normally put into the mobo, and since most cases are darn near 19cm wide it might be just barely too high stock as it is and such.
(for the record if it matters one reason for needing the extra video cards was a lower budget videowall/lots of monitors without the expense of what a normal 4-6 monitor driving card costs... an always on PC for stock trading which is also the media server hence wanting the extra hard drive bays for future expansion... ie why have two computers always on/do it both with one.)
I was trying to search the bitcoin boards for suggestions on physical cases (since that's where I found out about the card extenders, dont' have an account there so cant ask there tho) but didn't find anything useful, thought someone here might have an idea..
