just to let ALL know that paint they're fans, It can cause off weight, From a spot being thicker than the rest, ANd over time cause the fans to wear out faster Just make sure that you get a EVEN coat over the blades! the rest of the fan really doesnt matter. I know its a easy thing to do.. This is just a heads up
yeah i took that into consideration i didnt know it would wear out the fans more tho! i might actually just buy new ones i didnt like how the fans turned out...kinda tacky looking. can anyone point me to sum good fans i could mount to my D-14 ? (ill take the mounting piece on the old fans and put them on the new ones)
For a replacement for the 140mm Noctua fan, you could go with the Thermalright TY-140, which should be a direct drop-in replacement. It is also a PWM fan, so you can use a PWM header to control fan speed on it too if you want. For the 120 mm sized replacement, the GT AP-14 or AP-15 would be good choices (not PWM fans though). The Thermalright TR-FBD-1300 or TR-FBD-1600 fans would also be very good choices for the 120mm fan replacement.
The TY-140 isn't that awful brown/beige color of the Noctua; it's more a light grey or off white.
If you want a black frame, this Aerocool Shark looks interesting. No experience with their fans though. For another honest and inexpensive choice, you can also looks at the Yate Loon D14SM-12 too. Be aware that most any 140 mm sized fan besides the Noctua and Thermalright won't be able to use the Noctua mounting fan clips, since those 2 fans actually have the mounting holes spaced the same as a regualr 120 mm fan. Also, you can go with a 120 x 25 mm center fan of the same make and model as the other fan (or 2, if you want to go push/pull/pull with 3 fans).
