I have researched a lot about DIY Water Cooling. i have come up with many water block that i could easily make but dont know which one is the best .
i will just post some pics of the ones i was thinking about and you could help me pick the best one.
Option 1: 1/4in copper tubes soldered together, then flattened on the bottom, then maybe a thin copper plate soldered to the bottom of the tubes, or just the flat bottom Tubes directly touching the CPU
Similar Example:
option 2: a 3/8in or 1/2in thick 2x2in copper block with 1/4 holes (maybe 5 or 6 holes) drilled through with 1/4 copper pipe connecting with the holes
Similar Example:
option 3: a piece of 1/8 in copper plate with a acrylic cap with hose Barbs
Similar Example: NOTE: the block in this pic is in the bucket, best pic i could find
option 4: a 1/4in piece of copper with a maze path 1/8 in deep in to the copper, acrylic cap with barbs, similar to option 3
those aren't my blocks i just used them to help explain
thanks
Similar Example:
Similar Example:
thanks
