This is a bit of a follow up post of the one from yesterday.
I didn't get reactions to it but that's ok because there's a slight change of plans.
I decided this morning to build my system around my overclocking 'ambitions', limited by budget and I've decided to sail on the advice from people who know more about this then I ever will in my state as absolute overclock beginner.
I've been reading a lot but I lack all the experience and making just a theoretical choice based on sometimes confusing information isn't an easy thing.
my revised choices are:
The cpu:
My choice was be between a Pentium dual core and an Amd Athlon x3.
A reason for choosing Intel is that I read that only the Phenom ii X4 versions from AMD do not suffer at all from the L3 bug.
my I eye fell on the E5300. It's nicely priced with no significant speed difference with the E6500 I had in mind earlier.
The motherboard, I need your help choosing a suitable one.
I notice that many tuners publishing good overclocking results use Gigabyte boards so is this the choice to be?
Due to budget, if it will be a Gigabyte, I am limited to the G41 chipset versions.
The memory.
This is a confusing part because the information I read on many places seems to contradict.
Would I have no overclocking plans, the choice is easy: match the FSB with the Memory frequency and buy a solid brand.
With overclocking in mind you really need to help me out.
These are my issues:
A Gigabyte motherboard with, as reviewed by buyers, good overclocking qualities is the G41M-ES2L and it is nicely priced, however...
The DDR2 memory goes as far as 800 MHZ which is a nice match with the 800 MHZ of the E5300, no problem here.
But could it be wise to put 1066 MHz in to make an easy frequency raise possible? Gigabyte claims this board can handle 1066 Memory in overclocked condition.
I presume that raising it just a little instead of all the way to 1066 will not be a problem?
And in general, what about the 800 MHz limit's for the memory? Does this mean that a large increase above these frequencies will not be possible at all without instability problems?
I can also choose a DDR3 board, however...
the minimum memory speed is 1066 MHz which is higher than the E5300's 800 MHz.
As I understand, overdimensioning memory is never a problem since the motherboard automatically brings the memory frequency down to match the fsb's.
But what I understand is that DDR3 memory operating at the same speed as the DDR2 version works significantly slower due to the higher latencies and slower speed is not an overclockers wish. (Do I interpret this right?)
On the other hand, on this website, in "how to build a computer" choosing a DDR3 board is highly recommended and for overclocking purposes it seems ideal.
Is DDR3 preferred because it operates faster generally, no matter the higher latencies, because of the overclocking potential, or because of both?
summarized:
- Should I choose Gigabyte for a motherboard or are other brands like Asus or Asrock ok as well for overclocking purposes?
- Can I choose a DDR2 board limited to 800 MHZ and put 1066 MHz memory in being stable enough when the memory frequency goes up?
- Should I choose a DDR3 board and will I not loose memory speed?
- What is your opinion about the stability and speed of the Athlon CPU’s and is the L3 cache problem a reason to choose Intel in the concerning price ranges?
I hope you can help me out.
The cpu:
The memory.
summarized:
