- Dec 17, 2000
- Thread Starter
- #21
Compexpert said:does all that junk like the green stuff from the copper does that hinder the cooling performance ? cuss my maze 3 has alot green junk in it just wondering
That would be copper oxide....
i dont think it helps temps at all....
is it on the underside of your waterblock, making contact with your CPU?
I belive (could be wrong) that aslong as your dont have copper oxide making contact with your CPU you should be fine.....
If it is building up inside the block, you may have to clean the block out then......
http://www.members.shaw.ca/jordanstella/waterblock/
some quick pics of my ghetto setup
