If a mod would like to edit the title of this thread to say,
(NOW WITH PICTURES)
I'd be much ablidged, because here they are!
This was done completely by hand and took me upwards of an hour to do with my trust Black & Decker RTX with the etching and sanding bits. Once I can procure an inverter I'll be able to see this lit up INSIDE the shell.
Before ----------------------------------------------> After
Granted I have a really weak digital camera, but it's better than nothing. I lost my window of opportunity for painting the shell myself since the temperature outside dropped to 30f yesterday. I'll be taking the shell to an auto body shop soon so I can have the last detail sorted out (a nice silver paint job).
Aside from paint it's 100% complete. If I wanted to I could hook up the cables and let 'er rip. But, I do not yet know who this machine is going to. Either my friend will be buying it, or it's going in my personal stash, or it will be sold to a currently unknown person.
I have to use a Flex ATX motherboard because I was having a hard time getting processor for the SLot 1 motherboard I was going to use. It also save me a little space since I didn't have to make space for a PCI soundcard and could instead use the onboard audio (which works okay). The only two PCI slots are filled with a TNT2 M64 and a 56K modem. Both are mounted by a custom made Lexan backing plate (urg that took forever).
The CD-ROM drive is kinda naked. I completely removed the top cover and painted the tray silver. You can peep into the front window and see the CD spinning or loading. There was absolutely NO room to gracefully mount a floppy drive, so I just omitted it since I've had alot of problems with floppies getting scrambled (Grrrrr).
All said and done, I think it's the second-lightest machine I've ever built. It weighs in at 10 pounds and measures in at 10 x 10 x 9.
I will add more pics after it's painted. I've done over two weeks of work on this machine and the mounting holes I've cut into the back are a complete work of art. Nothing is hack and slash, nothing is second rate. This is the HARDEST and most labor intensive project I've ever completed.
*phew*
