Its better in about 0 ways and covers up what your doing which is annoying. Its much harder to minimize games since it only wants to open the start screen, why not have both options, etc..What's so terrible about a "start screen" as opposed to a "start menu"?
Edit: 100th post woo!
ALso windows 8 really annoys me, those dialogs that open on the side close if you go to do anything! Oh I need to set up VPN, copies password, has to start all over....
Wait so do you think every program out there should have to create its own windows library from scratch to display any information??
It is way less efficient. That is the bottom line for me when it comes to an OS and the GUI. How many clicks does it take to accomplish something? When Microsoft implemented the start screen, they took a major step backwards. You don't put a phone / tablet optimized gui on a full-on computer and expect it to be efficient. A mouse and keyboard offer much more control than simple hand gestures.
How is it less effecient? It takes the exact number of clicks and works almost identically. The only change they made was to make it compatible with touch-enabled devices, not specific to them.
It's optimized for small screen, touch devices. That was Microsoft's primary decision when it came to the design of Windows 8/8.1. From hidden menus, to how things scale on a high resolution screen, ALL of the little details are designed to make the GUI work well on a phone or tablet, but act as a hindrance when you have a mouse and keyboard at your disposal.
And you are not correct that it's the same number of clicks. Read this - http://www.dedoimedo.com/computers/windows-8-enterprise-rtm-review.html
It is one example. Running Windows Update in Windows 8 takes an additional click (and even more jumping through circles the first time) to run versus running it in Windows 7.
I work on servers all day, every day. I can tell you for a fact that Windows Server 2012 / 2012 R2 (server versions of Windows 8/8.1) are less efficient than prior versions. It takes me more clicks to log out when I'm done, more clicks to start applications, etc. If Windows 8/8.1 were measured by the user interface alone, they are a clear step BACKWARDS. Not like going back to the days of DOS... that would be an exaggeration. But it begs the question, why did they go backwards at all??? Just so MS could force one UI down everyone's throat for phone/tablet/pc? That's some really poor logic.
I honestly think most people who dislike W8 so much, probably didn't use it longer than a week.
If you are seriously rating the operating system by the number of clicks it takes you to do updates or log out, I'm not really sure how to respond to that. Updates in 7 and 8 take zero clicks to get to if you have it set to automatic.
Even it did take one more click (which, it doesn't, as ATM pointed out), how is that "way less efficient"? You're getting hung up on these tiny GUI differences and trying to make them some larger "problem".
Updates must be tested for the possible introduction of bugs prior to installing them. This is particularly important on mission critical servers, and when someone works for an IT service provider, as I do, you don't enable auto updates on ANY servers or workstations. Patching is already one of the biggest headaches in managing a Windows environment, and that's with protective measures already in place.
I'm logging in and out of various servers literally all day. What may seem like "tiny GUI differences" to you directly translates to more clicks for me, and that means it slows me down and makes more work for me. It's a matter of perspective. If I only used Windows 8/8.1 at home I probably wouldn't care, either.
A click is like a dollar. One on its own doesn't mean much. Add up 50 of them, though, and you can do something... like a date night at the movies.
Microsoft seems to think it is OK to make me and other engineers / admins click more to do our jobs. Why should I be ok with that?
BTW, it in fact DOES take an additional click to run windows update in 8/8.1 versus Windows 7. The link I posted has the proof. Go ahead and read it.
WSUS isn't in use? That would solve the checking for updates issue handily. You point the update server setting to your WSUS and approve/deny updates there. I've used this type of setup and it is incredibly simple. You don't even need to configure each station, as you'd specify the configuration in the domain.Updates must be tested for the possible introduction of bugs prior to installing them. This is particularly important on mission critical servers, and when someone works for an IT service provider, as I do, you don't enable auto updates on ANY servers or workstations. Patching is already one of the biggest headaches in managing a Windows environment, and that's with protective measures already in place.
I used Windows 8 Metro user interface without Classic Shell for a month upon its release. It's really great that you enjoy it. However, the majority of people (more than 50%), for whatever reason, do not. Microsoft is now officially getting rid of Charms, in a testament to its failure... Charms had appropriated a part of our work space and it was particularly intrusive in a deadline-chasing crunch when it was popping up, obstructing the view of work.I challenge you to use W8 for a month, then try and go back to 7.
everything in windows 8 is less clicks than people make it out to be. like omg im on the start screen, i need to go to windows updates..... start typing windows updates hit enter and boom theres the winderps upderps.
What if you're on the desktop and not the start screen? You must select settings, when the search defaults to apps only. Extra click vs. Win7. Why in the world are the apps and "setting" items separate anyway? I'm sure MS has some convoluted logic that explains...
Does it occur to anyone that maybe, just maybe, the reason why so many people make Windows 8 out to be inefficient because *gasp* it is?
