I'm running gentoo, and I've got gcc 4.3.2-r2 installed. I installed boinc via portage. It works fine, and I setup SETI, it downloaded the standard client and worked fine. I'm just trying to build my own fully optimized client.
I got the svn source,
Set it up
Configured it
And this is the output I got.
Any ideas?
Code:
shelnutt@gentoo-64:~/seti/$ svn checkout https://setisvn.ssl.berkeley.edu/svn/seti_boinc
Set it up
Code:
shelnutt@gentoo-64:~/seti/seti_boinc$ ./_autosetup
Configured it
Code:
shelnutt@gentoo-64:~/seti/seti_boinc$ BOINCDIR="/var/lib/boinc" ./configure --enable-sse3 --enable-fast-math --enable-sse2 --enable-sse --enable-bitness=64 CFLAGS="-march=core2 -O2 -pipe" CXXFLAGS="-march=core2 -O2 -pipe"
Code:
In file included from <command-line>:0:
./../sah_config.h:612:23: error: std_fixes.h: No such file or directory
In file included from vector/analyzeFuncs_fpu.cpp:16:
main.cpp:57:25: error: diagnostics.h: No such file or directory
main.cpp:58:18: error: util.h: No such file or directory
In file included from vector/analyzeFuncs_vector.cpp:39:
In file included from ./analyzeFuncs.h:31,
from vector/analyzeFuncs_fpu.cpp:19:
./seti.h:36:23: error: boinc_api.h: No such file or directory
vector/analyzeFuncs_vector.cpp:64:18: error: util.h: No such file or directory
main.cpp:60:23: error: boinc_api.h: No such file or directory
vector/analyzeFuncs_vector.cpp:66:23: error: boinc_api.h: No such file or directory
In file included from sah_gfx_main.h:29,
from main.cpp:62:
gdata.h:39:20: error: reduce.h: No such file or directory
main.cpp:63:23: error: graphics2.h: No such file or directory
main.cpp:72:22: error: str_util.h: No such file or directory
main.cpp:73:25: error: str_replace.h: No such file or directory
In file included from ../db/sqlrow.h:28,
from ../db/db_table.h:27,
from ./seti_header.h:43,
from ./seti.h:44,
../db/xml_util.h:82:27: error: error_numbers.h: No such file or directory
In file included from ./sah_gfx_main.h:29,
from vector/analyzeFuncs_vector.cpp:68:
./gdata.h:39:20: error: reduce.h: No such file or directory
vector/analyzeFuncs_vector.cpp:70:25: error: diagnostics.h: No such file or directory
from seti_header.h:43,
from seti.h:44,
from analyzeFuncs.h:31,
from main.cpp:75:
./seti.h:183:20: error: reduce.h: No such file or directory
./seti.h:184:23: error: graphics2.h: No such file or directory
from ./seti.h:44,
from vector/analyzeFuncs_vector.cpp:73:
./seti.h:40: error: 'APP_INIT_DATA' does not name a type
from main.cpp:62:
gdata.h:148: error: 'REDUCED_ARRAY_DATA' does not name a type
In file included from main.cpp:62:
sah_gfx_main.h:33: error: 'REDUCED_ARRAY_GEN' does not name a type
./gdata.h:148: error: 'REDUCED_ARRAY_DATA' does not name a type
In file included from vector/analyzeFuncs_vector.cpp:68:
./sah_gfx_main.h:33: error: 'REDUCED_ARRAY_GEN' does not name a type
sah_gfx_main.h:43: warning: 'sah_graphics_init' initialized and declared 'extern'
sah_gfx_main.h:43: error: variable or field 'sah_graphics_init' declared void
sah_gfx_main.h:43: error: 'APP_INIT_DATA' was not declared in this scope
sah_gfx_main.h:43: error: expected primary-expression before ')' token
In file included from analyzeFuncs.h:31,
from main.cpp:75:
./sah_gfx_main.h:43: warning: 'sah_graphics_init' initialized and declared 'extern'
./sah_gfx_main.h:43: error: variable or field 'sah_graphics_init' declared void
./sah_gfx_main.h:43: error: 'APP_INIT_DATA' was not declared in this scope
./sah_gfx_main.h:43: error: expected primary-expression before ')' token
from ./seti.h:44,
../db/xml_util.h: In function 'std::vector<T, std::allocator<_CharT> > xml_decode_field(const std::string&, const char*)':
../db/xml_util.h:888: error: 'ERR_XML_PARSE' was not declared in this scope
from seti.h:44,
from main.cpp:75:
../db/xml_util.h: In function 'std::string base64_encode(const T*, size_t)':
../db/xml_util.h:278: warning: array subscript has type 'char'
../db/xml_util.h: In function 'std::string base85_encode(const T*, size_t)':
../db/xml_util.h:373: warning: array subscript has type 'char'
from ./seti.h:44,
../db/xml_util.h: In function 'std::vector<T, std::allocator<_Tp1> > xml_decode_field(const std::string&, const char*)':
vector/analyzeFuncs_vector.cpp: At global scope:
vector/analyzeFuncs_vector.cpp:779: warning: deprecated conversion from string constant to 'char*'
from vector/analyzeFuncs_fpu.cpp:22:
./gdata.h: At global scope:
In file included from vector/analyzeFuncs_fpu.cpp:22:
main.cpp: At global scope:
main.cpp:161: error: 'APP_INIT_DATA' does not name a type
main.cpp: In function 'int main(int, char**)':
main.cpp:215: error: 'BOINC_DIAG_DUMPCALLSTACKENABLED' was not declared in this scope
main.cpp:216: error: 'BOINC_DIAG_HEAPCHECKENABLED' was not declared in this scope
main.cpp:217: error: 'BOINC_DIAG_TRACETOSTDERR' was not declared in this scope
main.cpp:218: error: 'BOINC_DIAG_REDIRECTSTDERR' was not declared in this scope
main.cpp:220: error: 'boinc_init_diagnostics' was not declared in this scope
main.cpp:239: error: 'boinc_parse_init_data_file' was not declared in this scope
main.cpp:240: error: 'app_init_data' was not declared in this scope
main.cpp:240: error: 'boinc_get_init_data' was not declared in this scope
main.cpp:242: error: 'sah_graphics_init' was not declared in this scope
main.cpp:244: error: 'boinc_init' was not declared in this scope
make[2]: *** [seti_boinc-analyzeFuncs_fpu.o] Error 1
make[2]: *** Waiting for unfinished jobs....
make[2]: *** [seti_boinc-main.o] Error 1
make[2]: *** [seti_boinc-analyzeFuncs_vector.o] Error 1
make[2]: Leaving directory `/home/shelnutt/seti/seti_boinc/client'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/shelnutt/seti/seti_boinc'
make: *** [all] Error 2
Any ideas?
