After 1year of solid performance from my most recent build it decides to start giving me crap. When I boot the fans spin and the harddrives spool only for 3-5 seconds. Then shuts down.
Initially I thought it might be the case shorting something. So I rebuilt the computer on a piece of cardboard. No luck. Then tried using a paper clip to ground the + - and boot. No luck there either.
I've checked everyhing that I can think of. Reset the CMOS. Reseated ram, CPU. Is my mobo dead? It's not booting fast enough to let me see the bios. Using my infared temp gauge gives me normal temps. Tried 3 differnt powersupplies.
Asus m2n-e w/ 4gb pc26400 and an amd 5600+ at stock speeds
Recently installed windows7 64 home and added 2 gb ram. About a month ago without fault until now
