My friend has a dell inspiron 530. I checked the cpu temps there fine sit in the 30's.
Only thing I can see is in the event log actually getting a few things. Wonder if any of these could be the cause?
Event Type: Warning
Event Source: EventSystem
Event Category: (52)
Event ID: 4356
Date: 9/25/2010
Time: 12:29:55 PM
User: N/A
Computer: REX-5F961DDDF34
Description:
The COM+ Event System failed to create an instance of the subscriber partition:{41E90F3E-56C1-4633-81C3-6E8BAC8BDD70}!new:{6295DF2D-35EE-11D1-8707-00C04FD93327}. CoGetObject returned HRESULT 8000401A.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Event Type: Warning
Event Source: Userenv
Event Category: None
Event ID: 1517
Date: 9/21/2010
Time: 5:16:36 PM
User: NT AUTHORITY\SYSTEM
Description:
Windows saved user OLIVERCORP\Rex registry while an application or service was still using the registry during log off. The memory used by the user's registry has not been freed. The registry will be unloaded when it is no longer in use.
This is often caused by services running as a user account, try configuring the services to run in either the LocalService or NetworkService account.
Event Type: Warning
Event Source: ASP.NET 4.0.30319.0
Event Category: Setup
Event ID: 1020
Date: 9/21/2010
Time: 3:51:17 PM
User: N/A
Description:
Updates to the IIS metabase were aborted because IIS is either not installed or is disabled on this machine. To configure ASP.NET to run in IIS, please install or enable IIS and re-register ASP.NET using aspnet_regiis.exe /i.
Event Type: Warning
Event Source: COM+
Event Category: (112)
Event ID: 5379
Date: 9/21/2010
Time: 3:50:46 PM
User: N/A
Description:
The server process has lost its connection with MS-DTC. This is expected if MS-DTC has stopped, or if MS-DTC failover has occurred on a cluster.
Server Application ID: {02D4B3F1-FD88-11D1-960D-00805FC79235}
Server Application Instance ID:
{34EB9B24-7A67-4E84-A7F4-4DBC7F687A8A}
Server Application Name: System Application
The serious nature of this error has caused the process to terminate.
Error Code = 0x8004d01c : A connection with the transaction manager was lost.
COM+ Services Internals Information:
File: f:\xpsp3\com\com1x\src\comsvcs\context\context.cpp, Line: 167
Comsvcs.dll file version: ENU 2001.12.4414.702 shp
Also getting these two under system.
Event Type: Error
Event Source: Service Control Manager
Event ID: 7000
Date: 9/25/2010
Time: 12:29:57 PM
User: N/A
Description:
The Kaseya Agent service failed to start due to the following error:
The service did not respond to the start or control request in a timely fashion.
Event Type: Warning
Event Source: Dhcp
Event ID: 1003
Date: 9/25/2010
Time: 12:29:49 PM
User: N/A
Description:
Your computer was not able to renew its address from the network (from the DHCP Server) for the Network Card with network address 001D099158DC. The following error occurred:
The operation was canceled by the user. . Your computer will continue to try and obtain an address on its own from the network address (DHCP) server.
Data:
0000: c7 04 00 00 Ç...
Event Type: Warning
Event ID: 4356
Date: 9/25/2010
Time: 12:29:55 PM
User: N/A
Description:
Event Type: Warning
Event ID: 1517
Date: 9/21/2010
Time: 5:16:36 PM
Description:
Event Type: Warning
Event ID: 1020
Date: 9/21/2010
Time: 3:51:17 PM
User: N/A
Description:
Event Type: Warning
Event Source: COM+
Event ID: 5379
Date: 9/21/2010
Time: 3:50:46 PM
User: N/A
Description:
Event Type: Error
Event ID: 7000
Date: 9/25/2010
Time: 12:29:57 PM
User: N/A
Description:
Event Type: Warning
Event Source: Dhcp
Event ID: 1003
Date: 9/25/2010
Time: 12:29:49 PM
User: N/A
Description:
Data:
