Hey all. I'm a little confused about how to properly use Arctic Silver 5. The instructions found here:
http://www.arcticsilver.com/arctic_silver_instructions.htm
say to put a bb sized glob of arctic silver 5 on the center of my AMD Athlon 64 CPU's heat spreader, drop the my heatsink/fan on the CPU, rotate the heatsink/fan slightly and then clamp it down.
But before finding the instructions on the Arctic Silver website, I googled on how to apply thermal grease and it seems much more involved than just applying a drop of AS5 on the CPU.
I'm finding instructions that involve spreading thermal grease across the CPU and prepping the heat sink with thermal grease. None of that is discussed in the Arctic Silver 5 instructions.
So should I go with the instructions on the Arctic Silver site or what?
Stats: AMD Athlon 64 3800+ socket 939
I'll be installing a Zalman CNPS9500 LED heatsink/fan
Thanks in advance for any advice.
Rey...
Rey...
