I'm not sure what the problem is here. I have 3 access numbers in my area, but only one of them works. The other two give my the "invalid UN/PW on this domain" error. (They had worked previously, but I do not know what changed)
Setup is simple. Navigate to your Network connection folder. Under the file menu click "new connection". A wizard will open, make your selections then hit next like this: Connect to the internet, set up my connection manually, connect using a dial up modem, enter the name for whatever you want to call this connection (AOL, AOhelL, doesn't matter), enter the access number for this connection, then finally enter the username and password exactly correct. Type it as it appears when you normally log onto AOL through the client - use proper case for the username and the password. Hit finish and the connection will be created. Double click on the icon and it will attempt to connect you.
Your password should be typed exactly as you created it, including proper case.
Your username may or may not be case sensitive, not sure but typing it as it appears on the welcome screen eliminates the username as a possible problem. It should include the "@aol.com" suffix.
I also recommend that you change your AOL password to only use a single case, either all upper or all lower case. That way you can be certain there was no mistake.
I know you already understand the majority of that if not all, but that will ensure that you aren't missing anything and that there are no secret tricks to the setup.
You can call AOL technical assistance but they will not help you with anything other than using the client. I have asked them for confirmations on support for v92 protocol on certain access numbers and also why only 1 of 3 access numbers support connections outside of the client... They were useless so I told them to forget about it and just tell me the access numbers again to confirm that I am dialing them correctly.
Starfoxer said:
i cant seem to get this to work. any way you can point me to a more in depth guide or explain it in a bit more detail.
i am dumb
i'm pretty sure i did it right. created new network connection, set up manually, selected dial up. for name i put AOL, then my access number when it asked for that, then for username section i did my [email protected], and for my password section i put that in.
i click on dial on my new network connection i have just created and it connects fine but tells me my password/and or username is wrong, which cant be the case as i've tried with @aol.com, tried tons of combinations of capitolizing letters etc.
just cant get it to work.
