You'll see about a 2-3°C drop.
I suspect a couple of higher performance fans (like TY-143) on NH-D14 would easily make up that difference.
Here is testing showing much greater differences than yours.
Much depends on how much heat CPU is making.
TY-143 at 1200-1300rpm has same performance as TY-140 at same rpm, which is near identical performance as Noctua stock fans.Where's the stock fan results here? Gives us nothing to compare to.
Post #9This fan is really silent, to my ear at max speed around 1300 rpm, it has the calm low freq hum and almost no bearing noise, overall it is far better than Noctua P-14.
Also the P-14 has the obvious noise starting around 1000 rpm and above.
Cooling performance wise, I'd say they similar or equal, but on the noise per performance ratio, hands down on TY-140.
Post #9
http://www.overclockers.com/forums/...40-fan-a-new-good-noise-performance-140mm-fan
I guess you are blind to the last sentence then.In that post all I seen a comparrison of was the noise levels compared to the noctua fans unless I overlooked something..And if I am not mistaken Noctua has new fans out since 2010.....
So the 14cm fans will have similar performance but the 12cm fan isn't? What will it be than? Certainly you don't think it will out-perform the TY-140 / TY-143 at 1200rpm.
And because I can't give you empirical data to support what is simply common sense it means nothing?
Yet you post 2-3c difference with no data at all to support it is supposed to carry weight?
I have supplied reasonable data to support my claim .. data show way more than 2-3c different.
But you supply nothing to support yours.
But yours is valid and mine is not.
I guess hypocrisy rules.
This seems more like petty bickering than constructive discussion.Ok so they are quieter, like I have been saying I can see that they are quieter. Yet no performance difference cooling wise over noctuas stock fans which is what originally got us started on this subject.
