Hey Guys,
I want to have my PC continuously cooled using liquid nitrogen and have continuous flow of liquid nitrogen to CPU. Only problem I see is that if I start cooling the air getting into the system, the entire thing would turn into an iceberg ( The snow and water would just short everything).
Since I work in the surface science laboratory and have used FTIR instrument that needed to be purged by nitrogen ( to remove air and water with it) I got an idea.
I could purge the entire PC with nitrogen. It would be cool to if you had only one input and one output for airflow on a PC assuming its completely sealed because that way one could purge it with liquid nitrogen boil-off ( completely dry nitrogen from the liquid nitrogen dewar). Once the gas inside PC is completely and exclusively nitrogen one could set up some kind of liquid nitrogen flow to CPU so no iceberg and
Let me know what you guys think?
Asphyxiation hazard maybe ?
Imagine if I also had a ln2 generating machine this could be a permanent fixture.
I'm telling you, just the insanity of the idea would make it worth the money.
Cheers
Cheers
