- Aug 26, 2007
- Dayton, Ohio
I've been playing with VMs recently, mostly using QEMU, and was wondering how i mignt copy a virtual OS to the harddrive in order to create a functional/bootable OS instead of just a VM.
I know that i'll have to edit my GRUB to boot the kernel, but that's not a probelm. (I should be able to jack the GRUB boot sequence from the /boot/grub/grub.conf on the (previously) VM and past it into my current GRUB file, allowign for changes in partition placement.)
Is there a better VM program that i could do this with?
My overall goal is to set Gentoo up 'in the background' and still be able to use my computer while i'm compiling everything - also when i fuber the settings i don't have deal with setting up all mu partitions.
The other thing is i want to set up Gentoo for my older computer but compile everything on my newer computer (currently running Ubuntu). The older computer is:
MOBO: Gigabyte GA-7IXE
CPU: Athlon k6 1Ghz Slot A
RAM: 756 Mb generic (or i can use 512 of it as ECC)
GFX CARD: PNY Nvidia Quadro FX 500
NIC: 3-Com 3C905B-TX
Sound Card: Ectiva MachOne (chipset EV1935)
Other: Hauppauge PVR-150
PSU (if you care): FSP460-601U it's a 460watt rackmount PSU.
My goal would be to allow some TV viewing or recording, and a lightweight WM (not Fluxbox - i just don't like it), internet use, and word processing.
I'm hoping to get an extrememly optimized Gentoo install but i have probelms determining the neccisary USE variables at startup. I'm also wondering if i should change the optimization higher, or leave it at 2.
