- Jul 4, 2013
- new york
seems if i disable 2 of the 4 cores, cool n quiet no longer works. i dont get the usual processor options in the OS power settings.
should it work this way?
Yea rgone I want it to scale back the CPU clock and voltages when at idle.
I looked around for some windows utilities and found ones like rmclock and crystalcpuid but they only work if cool n quiet is working.
When you disable 2 of 4 cores, you've cut the cpu's power usage right in half.
So if it's a 95w TDP Cpu, it's now 47.5w with only 2 cores running. You don't need cool and quiet at that point.
edit: should i see about 47w on HWmonitor? still shows 95w
