- Dec 25, 2007
Hey guys, I just got myself a Cooler Master ATCS 840 and would like to paint the interior full matte black myself. I notice some of the points have rivets on (like the top panel) and I need to get it off before I can remove it. My question is:
1. If I remove the rivets, can I replace it with screws later on?
2. To remove rivets, I just need to drill the center of the rivet and it will come off?
3. If I can't replace with screws and have to use back rivets, would there be chances that the replacement rivets that I use will cause the case to be shaky, i.e. the pieces are not properly riveted tight enough like the original ones?
Thanks for the help and hopefully I can get some answers that will clear my doubts so I can start modding soon.
