Ensorcelled
- Jan 11, 2013
Hi guys, first time posting here but I have been a longtime lurker! Anyway, I had a question on optimal air cooling for my case. I currently run the following fans;
x2 120mm Enermax Magma's Up Front (Intakes)
x1 200mm Coolermaster Up Top (Exhaust)
x1 120mm Coolermaster Case Fan on the Side (Intake)
x1 120mm Coolermaster Case Fan on the Rear (Exhaust)
Here's a poorly drawn diagram kinda showing how I'm setup currently; View attachment 121608
I'm running an i5-3570k Ivy Bridge and right now my temps under load (BF3 Ect) don't go above 72c on the stock cooler.
The main objective I'm wanting to accomplish is to switch out the stock CPU cooler with a Corsair H50 and I wanted to mount the Radiator on the rear 120mm. So, with how my case fans are currently setup, I was debating on mounting the Radiator as an intake so cool air directly contacts the radiator and basically leaving the top 200mm fan as the main exhaust.
Now with that being said, would I end up screwing myself over here by just leaving the 200mm as the only exhaust? I'm not sure which route to go here to be quite honest!
Any input/suggestions are greatly appreciated and again, great site!
