- Feb 20, 2015
Hello there, I'm using;
7700k oc: 4,8 ghz
My case is; SHarkoon bw9000
I decided to mod it a little bit, for reciving better airflow, here is what i did;
Oryginal Frontline panel is closed, and airflow is not so good, because there is not enough space for taking the air outside the case;
i decided to edit the front panel, and make an hole in it, so the 2x140mm fans can take air more easily, that is the result:
On the top side of the case i monted ToDAy 2x1200mm Arctic f12 rev 2.
and here are the effects overall:
Aida 64 test; min- 72 max- 83
modded; min- 61 max - 77
My question is, How should i put those 2 fans of top of the case, should they be as 2x coolers getting air out of the case, or maybe 1 should take cooler IN the case and 2nd just get the heat out....?
7700k oc: 4,8 ghz
