I can burn any other DVD but as soon as the burning process begins (after saving the image file), it fails..
Below is the log.. is anybody able to tell me why it doesn't work? or what does work?
9X0C-004C-AXCP-797C-7ET6-C723-****-****
Windows 7 6.1
AMD64
Wow64Process
Nero Version: 10.2.12.100
Internal Version: 10,2,12,100
Recorder: <MAT****A DVD-RAM UJ890AS>Version: 1.00 - HA 1 TA 0 - 10.2.12.100
Adapter driver: <Serial ATA> HA 1
Drive buffer : 1024kB
Bus Type : via Inquiry data
CD-ROM: <MAT****A DVD-RAM UJ890AS >Version: 1.00 - HA 1 TA 0 - 10.2.12.100
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD6400BEVT-80A0RT0 iaStor Port 0 ID 0 DMA: On
CdRomPeripheral : MAT****A DVD-RAM UJ890AS iaStor Port 0 ID 1 DMA: Off
=== CDRom-Device-Map ===
MAT****A DVD-RAM UJ890AS E: CdRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 4020MB (4117020kB)
Free physical memory: 2291MB (2346952kB)
Memory in use : 42 %
Uncached PFiles: 0x0
Global Bus Type: default (0)
Check supported media : Disabled (0)
16.12.2010
Burn DVD Image
22:38:16 #1 Text 0 File SCSIPTICommands.cpp, Line 464
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
22:38:16 #2 IMAGEGEN -10 File ImageGen.cpp, Line 398
Image was written as DAO.
DAOI:
MediaCatalogNumber = ''
TocType = 0x40
Finalized = 1
First/Last Track = 1 / 1
1: ISRC = ''
Blocksize = 2048
TrackMode = 'TRM_DATA_MODE1'
TrackConfig = 0x00
First/Last Index = 0 / 1
Index0FilePos = 0, Index1FilePos = 0, NextTrackFilePos = 6554488832
CUES:
LBRK: Last LBA on layer 0 = 2092895 / 0x1FEF5F / 4087MB
MTYP: Mediumtype = DVD (old format) (0x1C)
Image file name: <D:\TempImage.nrg>
22:38:16 #3 Text 0 File DVDPlusDualLayer.cpp, Line 1460
SetDriveCaps: Set LAST LBA of layer 1 to 2092895
22:38:16 #4 Text 0 File Burncd.cpp, Line 3521
Turn on Disc-At-Once, using DVD media
22:38:17 #5 Text 0 File DlgWaitCD.cpp, Line 314
[E: DVD-RAM UJ890AS ] Last possible write address on media: 4173823
Last address to be written: 3200433
22:38:17 #6 Text 0 File DlgWaitCD.cpp, Line 326
[E: DVD-RAM UJ890AS ] Write in overburning mode: NO (enabled: CD)
22:38:17 #7 Text 0 File DlgWaitCD.cpp, Line 2917
Recorder: MAT****A DVD-RAM UJ890AS, Media type: DVD+R DL
Disc Manufacturer ID: <RITEK>, Media Type ID: <S04>, Product revision number: 66
Disc Application Code: 0, Extended Information Indicators: 3
22:38:17 #8 Text 0 File DlgWaitCD.cpp, Line 499
[E: DVD-RAM UJ890AS ] >>> Protocol of DlgWaitCD activities: <<<
22:38:17 #9 Text 0 File ThreadedTransferInterface.cpp, Line 861
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (1 - DVD-ROM)
2 indices, index0 (150) not provided
original disc pos #0 + 3200434 (3200434) = #3200434/711:12.34
not relocatable, disc pos for caching/writing not required/not required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 3200434 blocks [E: MAT****A DVD-RAM UJ890AS]
22:38:17 #10 Text 0 File ThreadedTransferInterface.cpp, Line 1077
Prepare [E: MAT****A DVD-RAM UJ890AS] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x40; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 6554488832, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 3200434 | 0 | 0x00
3200434 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
MediaType: DVD+R DL
22:38:17 #11 Text 0 File SCSIPTICommands.cpp, Line 251
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
22:38:17 #12 Text 0 File Burncd.cpp, Line 4234
Caching options: cache CDRom or Network-No, small files-No (<64KB)
22:38:17 #13 PHASE 36 File dlgbrnst.cpp, Line 1827
Burn process started at 6x (8,310 KB/s)
22:38:17 #14 Text 0 File ThreadedTransferInterface.cpp, Line 2850
Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
22:38:17 #15 SPTI -1066 File SCSIPassThrough.cpp, Line 224
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1066)
CDB Data: 0xAC 00 00 00 00 00 00 00 00 64 00 00
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 24
Buffer x04b11d00: Len x648
22:38:17 #16 Text 0 File DVDPlusDualLayer.cpp, Line 1941
GetDriveCaps: LAST LBA of layer 1 is 2092895
22:38:17 #17 Text 0 File DVDPlusDualLayer.cpp, Line 648
Plausibility check for L0 size failed:
Last LBA L0: 2092895, Max LBA L0: 2086911, ReadCompat LBA: 265696
22:38:17 #18 Text 0 File DVDPlusDualLayer.cpp, Line 796
L0 Data Zone Capacity not set.
Max LBA L0 2086911 (1FD7FFh, 4075MB), next writable address 0 (0h, 0MB)
22:38:17 #19 Text 0 File DVDPlusDualLayer.cpp, Line 1460
SetDriveCaps: Set LAST LBA of layer 1 to 0
22:38:17 #20 CDR -100 File ThreadedTransferInterface.cpp, Line 1860
Parameter error
22:38:17 #21 TRANSFER -27 File ThreadedTransfer.cpp, Line 1222
Could not perform start of Disc-at-once
22:38:17 #22 Text 0 File DVDPlusDualLayer.cpp, Line 1460
22:38:17 #23 Text 0 File ThreadedTransfer.cpp, Line 273
Pipe memory size 83836800
22:38:17 #24 PHASE 38 File dlgbrnst.cpp, Line 1827
Burn process failed at 6x (8,310 KB/s)
22:38:17 #25 Text 0 File SCSIPTICommands.cpp, Line 301
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
22:38:17 #26 Text 0 File Cdrdrv.cpp, Line 11882
DriveLocker: UnLockVolume completed
22:38:17 #27 Text 0 File SCSIPTICommands.cpp, Line 464
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
