Help. I am a total noob...
warboss2003
*********************** Log Started 2020-03-16T20:58:43Z ***********************
20:58:43:************************* Folding@home Client *************************
20:58:43: Website: https://foldingathome.org/
20:58:43: Copyright: (c) 2009-2018 foldingathome.org
20:58:43: Author: Joseph Coffland <[email protected]>
20:58:43: Args:
20:58:43: Config: C:\Users\x\AppData\Roaming\FAHClient\config.xml
20:58:43:******************************** Build ********************************
20:58:43: Version: 7.5.1
20:58:43: Date: May 11 2018
20:58:43: Time: 13:06:32
20:58:43: Repository: Git
20:58:43: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
20:58:43: Branch: master
20:58:43: Compiler: Visual C++ 2008
20:58:43: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:58:43: Platform: win32 10
20:58:43: Bits: 32
20:58:43: Mode: Release
20:58:43:******************************* System ********************************
20:58:43: CPU: Intel(R) Core(TM) i5-2450M CPU @ 2.50GHz
20:58:43: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
20:58:43: CPUs: 4
20:58:43: Memory: 7.94GiB
20:58:43: Free Memory: 6.43GiB
20:58:43: Threads: WINDOWS_THREADS
20:58:43: OS Version: 6.1
20:58:43: Has Battery: true
20:58:43: On Battery: false
20:58:43: UTC Offset: 2
20:58:43: PID: 2704
20:58:43: CWD: C:\Users\x\AppData\Roaming\FAHClient
20:58:43: OS: Windows 7 Home Premium
20:58:43: OS Arch: AMD64
20:58:43: GPUs: 1
20:58:43: GPU 0: Bus:1 Slot:0 Func:0 AMD:4 Seymour [Radeon HD 6470M]
20:58:43: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
20:58:43: specified module could not be found.
20:58:43:
20:58:43:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:1800.8
20:58:43: Win32 Service: false
20:58:43:***********************************************************************
20:58:43:<config>
20:58:43: <!-- Network -->
20:58:43: <proxy v=':8080'/>
20:58:43:
20:58:43: <!-- Slot Control -->
20:58:43: <power v='FULL'/>
20:58:43:
20:58:43: <!-- User Information -->
20:58:43: <team v='32'/>
20:58:43: <user v='Augustinpaval'/>
20:58:43:
20:58:43: <!-- Folding Slots -->
20:58:43: <slot id='0' type='CPU'/>
20:58:43: <slot id='1' type='GPU'/>
20:58:43:</config>
20:58:43:Trying to access database...
20:58:43:Successfully acquired database lock
20:58:43:Enabled folding slot 00: READY cpu:3
20:58:43:Enabled folding slot 01: READY gpu:0:Seymour [Radeon HD 6470M]
20:58:43:WU00:FS00:Connecting to 65.254.110.245:8080
20:58:43:WU01:FS01:Connecting to 65.254.110.245:8080
20:58:44:WU01:FS01:Assigned to work server 192.0.2.1
20:58:44:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Seymour [Radeon HD 6470M] from 192.0.2.1
20:58:44:WU01:FS01:Connecting to 192.0.2.1:8080
20:58:44:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:58:44:WU00:FS00:Connecting to 18.218.241.186:80
20:58:45:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:58:45:ERROR:WU00:FS00:Exception: Could not get an assignment
20:58:46:WU00:FS00:Connecting to 65.254.110.245:8080
20:58:46:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:58:46:WU00:FS00:Connecting to 18.218.241.186:80
20:58:47:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:58:47:ERROR:WU00:FS00:Exception: Could not get an assignment
20:59:06:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
20:59:06:WU01:FS01:Connecting to 192.0.2.1:80
20:59:12:6:127.0.0.1:New Web connection
20:59:14:18:127.0.0.1:New Web connection
20:59:27:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
20:59:27:WU01:FS01:Connecting to 65.254.110.245:8080
20:59:27:WU01:FS01:Assigned to work server 192.0.2.1
20:59:27:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Seymour [Radeon HD 6470M] from 192.0.2.1
20:59:27:WU01:FS01:Connecting to 192.0.2.1:8080
20:59:46:WU00:FS00:Connecting to 65.254.110.245:8080
20:59:46:WU00:FS00:Assigned to work server 155.247.164.214
20:59:46:WU00:FS00:Requesting new work unit for slot 00: READY cpu:3 from 155.247.164.214
20:59:46:WU00:FS00:Connecting to 155.247.164.214:8080
20:59:48:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
20:59:48:WU01:FS01:Connecting to 192.0.2.1:80
20:59:51:WU00:FS00:Downloading 1.22MiB
20:59:52:WU00:FS00:Download complete
20:59:52:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14328 run:3 clone:36 gen:0 core:0xa7 unit:0x000000019bf7a4d65e6d11cb9edd20c3
20:59:52:WU00:FS00:Starting
20:59:52:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\x\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 2704 -checkpoint 15 -np 3
20:59:52:WU00:FS00:Started FahCore on PID 6400
20:59:53:WU00:FS00:Core PID:6412
20:59:53:WU00:FS00:FahCore 0xa7 started
20:59:53:WU00:FS00:0xa7:*********************** Log Started 2020-03-16T20:59:53Z ***********************
20:59:53:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
20:59:53:WU00:FS00:0xa7: Type: 0xa7
20:59:53:WU00:FS00:0xa7: Core: Gromacs
20:59:53:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 705 -lifeline 6400 -checkpoint 15 -np 3
20:59:53:WU00:FS00:0xa7:************************************ CBang *************************************
20:59:53:WU00:FS00:0xa7: Date: Oct 26 2019
20:59:53:WU00:FS00:0xa7: Time: 01:38:25
20:59:53:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
20:59:53:WU00:FS00:0xa7: Branch: master
20:59:53:WU00:FS00:0xa7: Compiler: Visual C++ 2008
20:59:53:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:59:53:WU00:FS00:0xa7: Platform: win32 10
20:59:53:WU00:FS00:0xa7: Bits: 64
20:59:53:WU00:FS00:0xa7: Mode: Release
20:59:53:WU00:FS00:0xa7:************************************ System ************************************
20:59:53:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i5-2450M CPU @ 2.50GHz
20:59:53:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
20:59:53:WU00:FS00:0xa7: CPUs: 4
20:59:53:WU00:FS00:0xa7: Memory: 7.94GiB
20:59:53:WU00:FS00:0xa7:Free Memory: 5.33GiB
20:59:53:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
20:59:53:WU00:FS00:0xa7: OS Version: 6.1
20:59:53:WU00:FS00:0xa7:Has Battery: true
20:59:53:WU00:FS00:0xa7: On Battery: false
20:59:53:WU00:FS00:0xa7: UTC Offset: 2
20:59:53:WU00:FS00:0xa7: PID: 6412
20:59:53:WU00:FS00:0xa7: CWD: C:\Users\x\AppData\Roaming\FAHClient\work
20:59:53:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
20:59:53:WU00:FS00:0xa7: Version: 0.0.18
20:59:53:WU00:FS00:0xa7: Author: Joseph Coffland <[email protected]>
20:59:53:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
20:59:53:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
20:59:53:WU00:FS00:0xa7: Time: 01:52:30
20:59:53:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
20:59:53:WU00:FS00:0xa7:************************************ Build *************************************
20:59:53:WU00:FS00:0xa7: SIMD: avx_256
20:59:53:WU00:FS00:0xa7:********************************************************************************
20:59:53:WU00:FS00:0xa7:project: 14328 (Run 3, Clone 36, Gen 0)
20:59:53:WU00:FS00:0xa7:Unit: 0x000000019bf7a4d65e6d11cb9edd20c3
20:59:53:WU00:FS00:0xa7:Reading tar file core.xml
20:59:53:WU00:FS00:0xa7:Reading tar file frame0.tpr
20:59:53:WU00:FS00:0xa7:Digital signatures verified
20:59:53:WU00:FS00:0xa7:Calling: mdrun -s frame0.tpr -o frame0.trr -cpt 15 -nt 3
20:59:53:WU00:FS00:0xa7:Steps: first=0 total=250000
20:59:56:WU00:FS00:0xa7:Completed 1 out of 250000 steps (0%)
21:00:10:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
21:00:27:WU01:FS01:Connecting to 65.254.110.245:8080
21:00:28:WU01:FS01:Assigned to work server 192.0.2.1
21:00:28:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Seymour [Radeon HD 6470M] from 192.0.2.1
21:00:28:WU01:FS01:Connecting to 192.0.2.1:8080
21:00:45:Saving configuration to config.xml
21:00:45:<config>
21:00:45: <!-- Network -->
21:00:45: <proxy v=':8080'/>
21:00:45:
21:00:45: <!-- Slot Control -->
21:00:45: <power v='FULL'/>
21:00:45:
21:00:45: <!-- User Information -->
21:00:45: <passkey v='********************************'/>
21:00:45: <team v='32'/>
21:00:45: <user v='Augustinpaval'/>
21:00:45:
21:00:45: <!-- Folding Slots -->
21:00:45: <slot id='0' type='CPU'/>
21:00:45: <slot id='1' type='GPU'/>
21:00:45:</config>
21:00:49:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
21:00:49:WU01:FS01:Connecting to 192.0.2.1:80
21:01:10:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
21:01:57:FS00:Shutting core down
21:01:57:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 6412
21:01:57:WU00:FS00:0xa7:Exiting, please wait. . .
21:01:59:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
21:01:59:WU00:FS00:Starting
21:01:59:WARNING:WU00:FS00:Changed SMP threads from 3 to 1 this can cause some work units to fail
21:01:59:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\x\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 2704 -checkpoint 15 -np 1
21:01:59:WU00:FS00:Started FahCore on PID 4548
21:01:59:WU00:FS00:Core PID:2216
21:01:59:WU00:FS00:FahCore 0xa7 started
21:02:00:WU00:FS00:0xa7:*********************** Log Started 2020-03-16T21:01:59Z ***********************
21:02:00:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
21:02:00:WU00:FS00:0xa7: Type: 0xa7
21:02:00:WU00:FS00:0xa7: Core: Gromacs
21:02:00:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 705 -lifeline 4548 -checkpoint 15 -np 1
21:02:00:WU00:FS00:0xa7:************************************ CBang *************************************
21:02:00:WU00:FS00:0xa7: Date: Oct 26 2019
21:02:00:WU00:FS00:0xa7: Time: 01:38:25
21:02:00:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
21:02:00:WU00:FS00:0xa7: Branch: master
21:02:00:WU00:FS00:0xa7: Compiler: Visual C++ 2008
21:02:00:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:02:00:WU00:FS00:0xa7: Platform: win32 10
21:02:00:WU00:FS00:0xa7: Bits: 64
21:02:00:WU00:FS00:0xa7: Mode: Release
21:02:00:WU00:FS00:0xa7:************************************ System ************************************
21:02:00:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i5-2450M CPU @ 2.50GHz
21:02:00:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
21:02:00:WU00:FS00:0xa7: CPUs: 4
21:02:00:WU00:FS00:0xa7: Memory: 7.94GiB
21:02:00:WU00:FS00:0xa7:Free Memory: 4.64GiB
21:02:00:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
21:02:00:WU00:FS00:0xa7: OS Version: 6.1
21:02:00:WU00:FS00:0xa7:Has Battery: true
21:02:00:WU00:FS00:0xa7: On Battery: false
21:02:00:WU00:FS00:0xa7: UTC Offset: 2
21:02:00:WU00:FS00:0xa7: PID: 2216
21:02:00:WU00:FS00:0xa7: CWD: C:\Users\x\AppData\Roaming\FAHClient\work
21:02:00:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
21:02:00:WU00:FS00:0xa7: Version: 0.0.18
21:02:00:WU00:FS00:0xa7: Author: Joseph Coffland <[email protected]>
21:02:00:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
21:02:00:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
21:02:00:WU00:FS00:0xa7: Time: 01:52:30
21:02:00:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
21:02:00:WU00:FS00:0xa7:************************************ Build *************************************
21:02:00:WU00:FS00:0xa7: SIMD: avx_256
21:02:00:WU00:FS00:0xa7:********************************************************************************
21:02:00:WU00:FS00:0xa7:project: 14328 (Run 3, Clone 36, Gen 0)
21:02:00:WU00:FS00:0xa7:Unit: 0x000000019bf7a4d65e6d11cb9edd20c3
21:02:00:WU00:FS00:0xa7:Digital signatures verified
21:02:00:WU00:FS00:0xa7:Calling: mdrun -s frame0.tpr -o frame0.trr -cpi state.cpt -cpt 15 -nt 1
21:02:00:WU00:FS00:0xa7:Steps: first=0 total=250000
21:02:01:WU00:FS00:0xa7:Completed 1062 out of 250000 steps (0%)
21:02:04:FS00:Shutting core down
21:02:04:WU01:FS01:Connecting to 65.254.110.245:8080
21:02:04:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 2216
21:02:04:WU00:FS00:0xa7:Exiting, please wait. . .
21:02:04:WU01:FS01:Assigned to work server 192.0.2.1
21:02:04:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Seymour [Radeon HD 6470M] from 192.0.2.1
21:02:04:WU01:FS01:Connecting to 192.0.2.1:8080
21:02:05:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
21:02:05:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
21:02:25:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
21:02:25:WU01:FS01:Connecting to 192.0.2.1:80
21:02:46:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
21:02:59:WU00:FS00:Starting
21:02:59:WARNING:WU00:FS00:Changed SMP threads from 1 to 3 this can cause some work units to fail
21:02:59:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\x\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 2704 -checkpoint 15 -np 3
21:03:00:WU00:FS00:Started FahCore on PID 4520
21:03:00:WU00:FS00:Core PID:6028
21:03:00:WU00:FS00:FahCore 0xa7 started
21:03:00:WU00:FS00:0xa7:*********************** Log Started 2020-03-16T21:03:00Z ***********************
21:03:00:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
21:03:00:WU00:FS00:0xa7: Type: 0xa7
21:03:00:WU00:FS00:0xa7: Core: Gromacs
21:03:00:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 705 -lifeline 4520 -checkpoint 15 -np 3
21:03:00:WU00:FS00:0xa7:************************************ CBang *************************************
21:03:00:WU00:FS00:0xa7: Date: Oct 26 2019
21:03:00:WU00:FS00:0xa7: Time: 01:38:25
21:03:00:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
21:03:00:WU00:FS00:0xa7: Branch: master
21:03:00:WU00:FS00:0xa7: Compiler: Visual C++ 2008
21:03:00:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:03:00:WU00:FS00:0xa7: Platform: win32 10
21:03:00:WU00:FS00:0xa7: Bits: 64
21:03:00:WU00:FS00:0xa7: Mode: Release
21:03:00:WU00:FS00:0xa7:************************************ System ************************************
21:03:00:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i5-2450M CPU @ 2.50GHz
21:03:00:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
21:03:00:WU00:FS00:0xa7: CPUs: 4
21:03:00:WU00:FS00:0xa7: Memory: 7.94GiB
21:03:00:WU00:FS00:0xa7:Free Memory: 4.63GiB
21:03:00:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
21:03:00:WU00:FS00:0xa7: OS Version: 6.1
21:03:00:WU00:FS00:0xa7:Has Battery: true
21:03:00:WU00:FS00:0xa7: On Battery: false
21:03:00:WU00:FS00:0xa7: UTC Offset: 2
21:03:00:WU00:FS00:0xa7: PID: 6028
21:03:00:WU00:FS00:0xa7: CWD: C:\Users\x\AppData\Roaming\FAHClient\work
21:03:00:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
21:03:00:WU00:FS00:0xa7: Version: 0.0.18
21:03:00:WU00:FS00:0xa7: Author: Joseph Coffland <[email protected]>
21:03:00:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
21:03:00:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
21:03:00:WU00:FS00:0xa7: Time: 01:52:30
21:03:00:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
21:03:00:WU00:FS00:0xa7:************************************ Build *************************************
21:03:00:WU00:FS00:0xa7: SIMD: avx_256
21:03:00:WU00:FS00:0xa7:********************************************************************************
21:03:00:WU00:FS00:0xa7:project: 14328 (Run 3, Clone 36, Gen 0)
21:03:00:WU00:FS00:0xa7:Unit: 0x000000019bf7a4d65e6d11cb9edd20c3
21:03:00:WU00:FS00:0xa7:Digital signatures verified
21:03:00:WU00:FS00:0xa7:Calling: mdrun -s frame0.tpr -o frame0.trr -cpi state.cpt -cpt 15 -nt 3
21:03:00:WU00:FS00:0xa7:Steps: first=0 total=250000
21:03:01:WU00:FS00:0xa7:Completed 1092 out of 250000 steps (0%)
21:03:41:WU01:FS01:Connecting to 65.254.110.245:8080
21:03:42:WU01:FS01:Assigned to work server 192.0.2.1
21:03:42:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Seymour [Radeon HD 6470M] from 192.0.2.1
21:03:42:WU01:FS01:Connecting to 192.0.2.1:8080
21:04:03:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
21:04:03:WU01:FS01:Connecting to 192.0.2.1:80
21:04:24:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
21:04:47:WU00:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
21:06:18:WU01:FS01:Connecting to 65.254.110.245:8080
21:06:19:WU01:FS01:Assigned to work server 192.0.2.1
21:06:19:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Seymour [Radeon HD 6470M] from 192.0.2.1
21:06:19:WU01:FS01:Connecting to 192.0.2.1:8080
21:06:40:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
21:06:40:WU01:FS01:Connecting to 192.0.2.1:80
21:07:01:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
21:08:04:WU00:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
21:10:33:WU01:FS01:Connecting to 65.254.110.245:8080
21:10:33:WU01:FS01:Assigned to work server 192.0.2.1
21:10:33:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Seymour [Radeon HD 6470M] from 192.0.2.1
21:10:33:WU01:FS01:Connecting to 192.0.2.1:8080
21:10:54:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
21:10:54:WU01:FS01:Connecting to 192.0.2.1:80
21:11:00:WU00:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
21:11:15:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
21:13:57:WU00:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
21:17:08:WU00:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
21:17:24:WU01:FS01:Connecting to 65.254.110.245:8080
21:17:25:WU01:FS01:Assigned to work server 192.0.2.1
21:17:25:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Seymour [Radeon HD 6470M] from 192.0.2.1
21:17:25:WU01:FS01:Connecting to 192.0.2.1:8080
21:17:46:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
21:17:46:WU01:FS01:Connecting to 192.0.2.1:80
21:18:07:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
You aren't doing anything wrong. The work servers are getting hammered with all the new folders so you may not get work units for long periods of time.
True that. My farm has taken a big hit with the lack of work units.
Looks like the CPU is folding OK using 3 of the 4 cores. The AMD 6470m GPU is still shown as supported by FAH in the gpus.txt file. The 6470m is a pretty weak gpu (160 shaders, 4 ROPs) and would have a difficult time completing a work unit within the deadlines. Also, a notebook might have power supply and heat removal issues folding on both CPU and GPU at same time, even with a cool pad.
My suggestion would be to delete the GPU slot and manually configure the CPU slot to use all 4 cores. The FAH default setup configured 3 CPU threads on the CPU slot because one core/thread is reserved per gpu slot for gpu data transfer and checkpoints.
Manually editing the FAH configuration.
In FAHControl, select "configure" and then the "slots" tab.
To remove the GPU slot, select the gpu slot, then the "remove" button in the lower right corner.
To edit the CPU slot, select the cpu slot, then the "edit" button in the lower right corner. In the upper left, change the number of CPU threads to 4 (defaualt is -1). Then save all the changes with the "OK" button in lower right corner and the "save" button in lower right corner.
The cpu thread can be edited while a wu is in progress . However, a wu will not run on more threads than were configured when the wu was downloaded. The next wu will use all 4 cores. Note, it is possible to decrease the number of core/thread use on the existing wu.
