- Dec 1, 2008
- Last 30 Years NE OH
I never new Windows 7 parked cores by default. For people that are not aware of this default state, here are some tips to unpark cores.
Go under msconfig / Boot / Advanced options / Make sure the number of processors is checked according to your processor.
I have tested this on a clean copy of Windows 7 x64, and it works perfectly - all Cores are available at all times and none are ever parked.
- Go to Regedit
- Find this key:- " 0cc5b647-c1df-4637-891a-dec35c318583 "
- Within this key, there is a value called: " ValueMax "
- This value represents the % number of cores the system will park - the default 100% ie: all Cores are potentially park-able
- Change the value from 64 to 0 so the " ValueMin " and " ValueMax " are both zero
- You will have to find the key a few times and repeat the process for each time it is found - the number of instances will depend on the number of power profiles in your system. I have 2 profiles set in my bios. I found this key twice. Your system might differ.
- Do a full shutdown and power-off and cold-re-start
- Go to Regedit
