- Jul 7, 2011
I was looking at the Corsair 600T White and found out that the cooling wasn't that great. Bit-tech.net said that it may have been because the 200mm fan on top is more toward the front than normal. I was thinking about replacing the top 200mm fan with 2 120mm fans, would this improve airflow and cooling. I will be using the Corsair H50 for my CPU the CPU is a 2600K the GPU is a GTX 580.
