- Dec 1, 2007
- Near Toronto Canada
Very nice cable management for your first try. I hate MSi boards and stock coolers but otherwise very nice.
Once you pick a color of LED that you like for the internals that you want to stick with, pick up some colored thin electrical tape in the same color (blue, green, red, etc) and cover the power LED for the case with a little square of it. Now you have a power light that matches your case light. The light comes through the tape very bright. I turned my 500R LED blue from white using this method.
*sigh*... another Zalman victim...
Don't buy anything from Zalman. They just went under for sucking so much. Seriously terrible parts all round. Their coolers are epic fails every time. If you can, return it.
No, they went under from fraud. They're solid coolers.
They perform poorly per $ though.
They've made some massive coolers too, but they pretty much owned the low noise crown for a long time.
