- Jul 4, 2014
- College Station, TX
I just added a Corsair H105 liquid cooler to my system replacing a Phanteks PH-TC14PE air cooler. Installing this cooler in a vintage Alienware Aurora case (2006) was problematic but I was able to do so by installing the radiator vertically instead of what i would suppose is recommended, horizontally. I don't think that mounting the radiator vertically affects its performance as it is keeping the CPU at 28c and has not broke 42c under full load. The Phanteks incidentally performed equally with the new liquid cooler. My only complaint with Corsair concerning the installation of their HOO5 is that their documentation is really brief. For instance, they never mentioned if the radiator could be mounted vertically. Additionally, the instructions dictate that the power to the pump be connected to a fan connection on the mother board but does not indicate what settings (for mother boards that you can adjust the fan speeds through the bios) to use. I have a Sabertooth mb and set my fan speed to turbo mode, which leaves the question of whether or not Corsair recommends full voltage to the pump at all times? Since the cooler has a 5 year warranty, I have chosen to run the pump at full power at all times, but does that help our hurt its cooling performance? I would appreciate any input from anyone else who has installed this system. Specifically, I would like to hear temperature readings from others with full ATX cases with similar CPUS.
INTEL I7-4930K CPU, Alienware Aurora Case, Corsair Vengeance 48GB 2133mhz PC3-17000, ASUS SABERTOOTH INTEL X79 SOCKET MB, Intel high speed 600gb SSD, 2 WD 1TB 7400rpm Hard Drives Raid0, THERMALTAKE TOUGHPOWER 850W DIGITAL PSU, Corsair H105 Cooling,
