- Nov 21, 2010
Hey guys I got a new CPU cooler. The Corsair H100. I am currently using the HAF 932 series case. I replaced the fans the Corsair H100 came with, with 4 cougar 120mm PWM fans for a push/pull config. I am wondering if I should mount it so its pulling cold air from the top of the case, through the rad.. or pushing the air from inside the case through the rad exhausting the air out of my case through the top?
What method of exhaust will yield me the best results temperature wise? I currently have a 140mm cougar fan exhausting air out the back of my case.
I run a crossfire configuration of 2x XFX 6970s that idle at 40c and max out at 63c
If you an unfamiliar with the Haf 932 here is a link. http://www.newegg.com/Product/Produc...82E16811119160
