once i ve built it i will have look what i can do at the minimum level as oc is something i havent done before.IMHO either would be massive overkill if you are not overclocking.
Thanks for your help1, You probably don't need 1000W.
2, I wouldn't buy that 1000W model anyway even if you could.
3, H100 is your best bet (short of a full loop), do not buy the big water. It's frankly crap. And the H100 requires no maintenance once installed. You'll get to 4.5ghz probably, but don't expect to hit 5ghz unless you have a golden chip.
4, Back to the power supply.
If you only are going to get a single graphics card, and do not plan to SLI or Xfire (depending which card), you'd be best served by a quality 650 ish watt PSU.
Depending on where you are buying from I would consider different options. If you are in the US and buying from newegg.
Seasonic X-650 PSU Is the power supply I recommend for a single card setup. (Though if you pick a mid-range card; this PSU will power two mid-range cards fine). Though I'm a firm believer of having a resolution of 1080p or less, stick to a single more powerful card.
What are your plans for graphics card(s)? And what resolution will you be running?
Oh and, not to burst your bubble.. But your Motherboard and your Processor DO NOT WORK together.. The i7 975 is an X58 platform (LGA 1366) CPU. That Motherboard is an X79 (LGA 2011) socket motherboard... They are not compatible..
K33n, you might want to post your budget, what you have, and what you need to buy in the General Hardware section of the forums.
You should be able to get decent money for that 975. However, you don't NEED to upgrade your CPU, it's still very, very powerful. My 920 is [basically] the quad core version, and I don't see myself changing it anytime soon.
That'd be fine if he didn't already have the motherboard lol. (At least that's what I gathered from one of his posts.. That he already has some of the parts sitting next to him :\).
T
Mjolnir i know motherboard supports quad channel but will my old tripple
channel Rams still work on this or do i have to change them aswell??
