- Apr 16, 2012
Hi,
Normally I build my own PC's but I picked up an Alienware Aurora R3 for pretty much nothing a few months ago and upgraded the RAM, and added a GTX 680 and an SSD.
I'm looking at doing my first overclock beyond the factory overclock to 4.1Ghz that it came with.
The cooler in it is a Corsair H50 which currently has just one stock fan which according to this (http://www.legitreviews.com/article/1025/2/) has specs of 59CFM and static pressure of 3.57 mm H20.
I want to run two fans in push/pull and have 2 Enermax TB Silencefans at home (http://www.enermax.com/home.php?fn=eng/product_a1_1_2&lv0=4&lv1=32&no=143) which have a higher CFM at 71 but a lower static pressure of 1.676 mm H20 which leads to my question.
Am I better off just using the 2 enermax fans or should I use the stock fan with it's higher static pressure for the "pull" and an enermax for the "push"?
According to page 6 of the review I linked earlier (http://www.legitreviews.com/article/1025/6/), using two Noctua fans which have a similar static pressure to my Enermax fans but a lower CFM they seemed to achieve some decent results.
Any thoughts?
Thanks
Any thoughts?
Thanks
